Can I import excel web app on joomla?
Hi guys,
Can I import excel web app on joomla? If using a joomla website creation is there a way that the user can export or attached an excel web application file? My website is a forum about health and some users are asking me to add an attach file button for them to send links and files through the forum. I need your suggestion and advice.
Expecting some help, thank you.
Answered By 5 points N/A #184653
Yes, you can import excel web app to Joomla based website.
1. Firstly you can save the excel document as HTML file. Then through the HTML button of the editor of your website paste the content.
2. Secondly you can use the “Content Uploader” to export excel or any data file to Joomla. Check out the link https://extensions.joomla.org/extensions/extension/migration-a-conversion/data-import-a-export/content-uploader/. It will quickly upload excel web apps and helps you to avoid time consuming, manual work.
Hope you will now be able to help your users upload their files to your Joomla website.
