Can I install anti spyware alone? will that work?
Hi guys,
I want to know that installing anti spyware alone will keep my PC safe from all kinds of virus or I need to install anti virus and anti spyware also. I'm really confused with this regard please suggest me a solution to keep my PC away from all kinds of virus,malware and spyware.
Answered By points N/A #184099
Spyware and virus are different and their working method as well. Protection from both is different, too.
There are many antispyware programs that work alone which will only protect you against spyware. Spyware is the technique that hackers use to intrude into other systems and watch everything done on the system by staying behind the curtain. Antispyware will only keep you safe from stealing your data.
In order to have the perfect protection, you should use any good internet security solution. This will keep you safe from spyware, virus and other malwares.
There are many good ones but Kaspersky Internet Security, Norton Internet Security, Avira Internet Security, BitDefender Internet Security etc. are the best.
