Can I install apps on Micromax mobile x265?
Someone gave me a Micromax Mobile x265 GSM 900 as a gift. Can I install some games and apps on this phone? Can I also browse the internet? Need feedback for my Micromax Mobile x265.
Hi there,
Your Micromax X265 can access internet using Opera mini web browser but it is charged by your network provider. It doesn't support WiFi connectivity. You can download games and apps on your web browser but you'll have to pay for it unlike Android devices which most of the apps are free to download. But the good thing is, it is powered by dual SIM. It comes with a built in Yamaha audio amplifier, an FM radio and, you can save your downloaded songs to your Micro SD Card which can be expanded up to 8GB.Â
It had an LED torch light to help you find out objects in the dark.
Hi there,
You can browse the Internet with Micromax X265 but I think it is a very boring phone (Don't Mind). Because it can not browse web sites like Facebook & It hangs during work frequently. The internet can be browsed by Opera mini web browse {WAP 2.0/xHTML (Opera Mini)}. You can download games and apps from websites but it does not support Java games. The good quality thing is, it is mechanical by dual SIM.
It comes with a built in Yamaha audio amplifier, an FM radio and, you can save your downloaded songs to your Micro SD Card which can be expanded up to 8GB. It has long battery life.
