Can I install winning 9 update 2011 free automatically?
I want the winning 9 update 2011 free. Do I need to install an older version? Or can I install winning 9 update 2011 free automatically?
Hi Mikhail, you can go to this link for free update of winning 9. http://www.pes-patch.com/2011/02/world-soccer-winning-eleven-soccer-2011-update-2.0.html. The installation of this version is just easy simple steps. Just click download, and then run the exe file to install and get etypesetup. It is a full version and previous version is not needed.
It is always safe that before update or installation to backup the files that are overwritten by the File Archive. Because there are files required to update the game or play online. But there are some No-CD/fixed exe files work fine in single player, so use the original exe. And most of all, some game trainers are virus so be careful on that if you play online.
Hope this help.
