Can I locate software or drivers for my computer?
Of course I can facilitate you to set the drivers or software for your system. Many ways to download and locating the drivers and software from the internet. If you know the device model and about its manufacturer then you can simply type it in Google and can search and get results. On the other hand if you want to search out the driver or software on the device which are inside your system and produce by OEM, Gateway or Dell. Simply go to the webpage of that manufacturer and you can find the drivers. You can check all the list of manufacturing in internet. If your manufacturer exists just visit the website of that.
Thanks
If your computer is a branded computer, you can go to the manufacturer's website then go to the Drivers and Downloads page or the Support page. Look up the drivers for your system model and the website should be able to give you a list of drivers that you need for the system. Some brands like Dell have their website configured to ask for the computer's service tag and after you enter the information it will take you to a page where all the needed information and downloads for the system is available.
If you have a system that you built yourself using custom parts, you just need to go to the manufacturer's website of each of the components in your system. You should be able to get the drivers from there. Windows 7 also has the capability to update your drivers, so if you have this operating system, it may not be necessary to visit any website, just let Windows update your system.
