Can I lock controls in Silverlight data form designer view?
I don’t want my co-developers messing with my design so please teach me how to lock controls in Silverlight data form designer views.
Thanks in advance.
Thanks in advance.
You can lock controls in Silverlight data form designer. You can set a password to the data form and give the password only to the trusted users. By doing this, only the users to whom you give the password will be able to access the data forms. You can also put the captcha software on your data forms to avoid spam. The users who want to access have to enter the captcha code and then they can access the data forms.
This helps reduce spam from the Silverlight data forms. You can also set a user authentication system where the password will be sent to the users email id. The users will then have to click the link in the email to access the data forms.
Hope this information helps you.
Notifications
