Can I make all columns the same?
10 points
Posted on - 04/20/2015
I'm using an Excel spreadsheet, and I need to make all the columns the same size on multiple tabs. I know I can go in and change the column width on each individual column, but that will take me a long time. Is there a way that I can just do one tab and transfer it over to every tab on the spreadsheet? Thank you.
