Can I apply a 640×480 HD screen cap from prototype as wallpaper in Windows 7 starter edition?
Its says not authorized.
Is there a way around this without having to upgrade my OS?
Would an image hosting software allow me to make the screen cap prototype 2 as my wallpaper?
Can I make Screen cap prototype 2 as wallpaper?
Hello John,
Many users of the window 7 starter edition are furious because they can not change their wallpaper.
But there is a solution for this problem.
There is a program that is fixing all the problems.
It is very easy for using, you will not have any problems with it.
You can get it for free.
Here is a link of a page which can give you this program for free:
I will be happy if this help you and if you change your wallpaper.
