Hello guys. I was wondering if I can make screensaver from Microsoft clock? I would like the analog clock with the digital time below to be my screen saver. I'm on a Windows XP 64 bit SP 2 system. Thanks in advance.
Can I make screensaver from Microsoft clock?
Hi Elyssaguadalupe,
Windows XP does not have a clock Screensaver. But there is a way around it. If you want a clock as a Screensaver you have to download it. Below is a link that will take you to a site that has many different types of clock.
https://en.softonic.com/s/full-version-free-clock-screensaver/windows-xp
You will choose one, download and install it on your Windows XP. However, the latest versions of Windows from Windows 7 onwards have clock screensavers. You might want to upgrade to these operating systems but do not do it solely for the clock.
Hi Elyssa. Your operating system doesn't have an analog and digital screen saver, but there are many types of software that you can download personalized screen saver that is compatible with your Operating System or you can easily upgrade your operating system into windows seven or windows 8 that already have an application to change screen saver into digital with analog clock.
