Can i make virtual gps on my Mac system?
I want to convert my Mac operated computer into virtual GPS. Is it possible to make virtual gps mac? I searched on the internet and found that you can make virtual GPS on your Android devices and Google also providing such type facility. I want to do this on Mac. Please help me out, how to do this. Is there any free program available to resolve my problem? Any ideas and suggestions are welcomed.
Best Answer by Franke Mary
Answered By 10 points N/A #183739
Hallow,
Garmin offers a wide suite of plug-ins that can be downloaded to allow its GPS units to interface with Mac OS X.
These plug-ins include essential software such as RoadTrip, which allows you to transfer customized maps to your device;
BaseCamp, which displays the area's terrain and allows you to geotag photographs; and MapInstall,
which helps you install maps on your device. Simply download the free software and install it on your computer to interface with the GPS.
Hope you will enjoy it.
Thanking you
Franke Mary
Answered By 0 points N/A #183741
Hello Lance
Yes it’s possible to make your mac pc into virtual GPS.
There is a great tool named as Meraki Systems Manager.
You can download it from it from cNet and from file buzz. First secure your mac system using scanner.
