Can I modify android launcher app icon size
Hi there! I have a Samsung Galaxy using Touchwiz launcher.
I'm planning to modify android launcher app icon size.
Is it possible?
Also want to download so I can replace my launcher.
Is it possible?
You can't modify icon app size on TouchWiz Launcher. The only thing you can modify is the widget size, and the grid.
If you want a launcher that can modify the app icon size, I suggest that GO Launcher Ex is the right launcher your device must have. You can modify the icon size.
There are 3 options to customize the size of the icon: 1. Big (Recommended) 2. Small (Default) 3. Customize.
To customize the size of the icon app, just tap Menu > Preferences > Visual Settings > Icons > Icon size then tap Customize (drag your finger horizontally to induce or reduce the size).
