Can I place registry entry comments in .reg files?
        30 points
                                        Posted on - 05/22/2013
        Hi there. Can someone help me out here? Can I place registry entry comments in .reg files and is this possible? Some say you can do this by putting ; or # at the beginning of the line. So, what is the correct way? I'm on Windows XP 64 bit.
