Hi guys,
Can i play audio from pak files? I just want to clear things up regarding .pak file extensions and needs to ask if I can play those audio from pak files? I am using windows 7 starter operating system. I hope this has nothing to do with compatibility issues.
Expecting some help, thank you.
Hello Deborah,
WIndows 7 Starter Edition Operating System comes with a preloaded Media Player 12 which does not support .PAK file extension. You can download other Video/Audio Players such as:
Ace Media Player
NoteWorthy Player
YUV Player Deluxe
XPlayer
BS Player
Camtasia Player
And a lot more other players that are able to play .PAK Video/Audio file extensions. Hope this helps!
Kroskey
I think you need to play a .pak file so dear you can do this only when your program supports this file format. .pak file format is not supported by any media player with in window 7 and you need to download another player that really supports your file format so you can play your file.
Smith Thompson
