Can I play Delta force in my pc?
Hi guys, I am using Pentium 4 Dual Core Processor with Windows XP. CAn I install and play delta force?
Hello Mr. Sattar,
Yes, you sure can play this wonderful game.
To install and play Delta force, you need to have following configurations:
1. Operating system: Windows XP/Vista.
2. Processor: Pentium 4 or dual core processor.
3. RAM: 512 mb/1gb.
4. Hard disk drive: 10 GB free space.
Note: These are minimum requirements. You can enjoy more if the configurations are better.
Thank you for your question. Enjoy gaming.
Most of the latest High End games unfortunately do not support Dual Core below especially 3d Games. Check to see if your computer meets the system requirements of that specific version of the game by entering the games link. You should be able to find the system requirement if your computer fails one of the requirements of the game.
Don't waste your time buying and installing it. Because you will be having trouble with it and you might end up reformatting your computer which is very laborious. The best way to solve the problem is upgrade your computer and then install Delta Force after. Now the game and your computer should work like a charm and trouble free.
Hope this help you mate.
