groat n
Posted on - 01/26/2013
Can I play shout cast radio on my blackberry 8520?
I also want to listen and record radio programs on my phone.
If there is any software or tool available, then share the information with me.
I shall be very thankful to you if you help me out.
Thanks
Hi there,
As far as I know there is no shout cast radio accessory on your blackberry 8520. You may want to sync your recorded songs from your device using blackberry media sync.
This will work to Blackberry Curve 8520/8530 Smartphones. To enable this, you should connect your device to your computer via USB port, Open the desktop Manager¾
Click the Media icon, After this, you may see the Launch tab where you should open this, this is located in the Blackberry Media Sync, Select your music applications and choose one of the Synchronize check lists where you have 3 options, then Click sync music, click Ok then Exit.
Finally you can now view on the home screen your transferred media files by clicking MEDIA, MUSIC, PLAYLISTS consecutively.
There is possibility to see your playlists filed on Random Music Playlist.
Thanks,
Steele Ney
