louise bowl
30 points
Posted on - 05/05/2013
I just purchased a label printing machine and wants to make sure that I will be able to print barcode on vb6 report so that I don't have to do the formatting of the files and data again. I have a very long list of barcodes that has to be printed on our products' label.
Can I print barcode on vb6 report?
I don't think that there is problem in printing barcode within VB, what I know that there is an SDK at VB6 to create a print barcodes, in the attached text file you will find example code for using SDK for barcode creation and printing, within comments in the code you will know the steps that you will follow to complete task, if you just need the code for printing you can copy the printing portion and use it in your own code.
