Can I put Windows 7 ultimate inspirat 51 to iPhone?
I was just wondering if there's a way I can put windows 7 ultimate inspirat 51 to iphone? I have Iphone 4s with OS 5.1 and not jailbroken. Thanks
Hello Warren,
There is no way for you to install a Windows OS in iPhone. The only way to have Windows OS is to obtain a device that comes with it. You can do a search for good Windows Phones that can be compared to the iPhone and buy one. You can however test drive Windows OS on your iPhone by going to the following website using your browser in your iPhone: https://www.microsoft.com/en-us/windows/windows-10-mobile-upgrade
Hope that this answers your question.
P Vhilary
Hi Warren,
It is really not possible to obtain a Windows OS to your Iphone. The best way to have one is by getting a smartphone that has a built in Windows OS like Nokia lumia phones. They are great performing phones and trying to experiment with your Iphone's OS might lead you to a broken or damaged phone. Hope this helps.
Notifications
