Can I remove the SHUTDOWN option from the START menu
1800 points
Posted on - 06/19/2011
I am getting some issues with some users that accidentally hits the Shutdown button under the Start Menu that tends the Terminal Server on the Application mode to shut down. So I added a Logoff button through a GPO but I am still thinking If it is possible to remove the Shutdown button or disable it on the Start menu in which users can still be able to restart without knowing that there is no Shutdown button?
