I use Office 2000 version on my Window XP. But now I have done some updating to my system so I thought to give a try to the Window 7 as i have learned that it is more secure. But I want to remain on the same old version of the Office 2000, so can i run the office 2000 on Window7.
Can I run office 2000 on windows 7
Actually, it is quite difficult to give an exact answer for your question without any further detail regarding your computer system.Â
Usually, as stated by the Microsoft, Office 2000 version is not supported by Window XP OS. Yet, there are instances where this is quite possible, depending on the fact that the machine is a 32 bit system. However, you can try & if it does not work, it is time to move another newer version.
Best Regards!Â
