Can I run RTSP over WAP?
Hi Experts,
I want to run real time streaming protocol over Wireless application protocol. Is it possible to rtsp over wap on symbian mobile phone?  I want to play RSTP on real player. Is there any tool or software available to run RTSP over WAP?
Best Answer by Malone Toby
Answered By 0 points N/A #178677
Hello Bryan,
I think that there is  a solution for your question. It is possible to run RTSP over WAP. You should configure your streaming settings. Go on Settings > Configuration > Personal Configuration. Then press Option and select Add New and select Streaming. At the end go to Media > Media Player and activate the streaming setting. I think this will help you to solve your problem.
Answered By 0 points N/A #178678
Hi Bryan,
I think that it is possible.
1. Try to configure Steaming settings on Settings > Configuration > Personal config.
2. Then press Options and select Add New.
3. Then select Streaming.
4. Now Go to Media > Media Player and activate the streaming settings.
5. Then select go to address and input the streaming site.
