I am creating an Excel File for my group schoolwork and wants to have it in csv templates. I am planning to send the file via outlook to my group mates. Is csv template for outlook possible or do I have to do it differently?
Can I send csv template for outlook?
How are you? Hope you are doing great, CSV files not at blocked list in outlook to have more information you can launch this page outlook you will find blocked list, finally you can send CSV template by outlook and no need to convert it to another extension
Regards.
Hi there! I have here additional software that might help you with your query. This software will help you send .Csv files and even more than that. It will help you with that workload that you are doing with your school group activity. Just open this link and it will give and answer everything about how to send your .Csv to your group mates. The link I gave you will let you use a powerful software where you can send csv files to all your group mates and will give you some other feature like you can gather all the csv files in one location and extract them when you need the files.
Click this for website on how to send csv
