Hey everyone,
I have a work in which I have to establish Remote Connections now and then. But, I cannot use the shortcut “Ctrl + Alt + Del” on the Remote Machine. How can I send Ctrl Alt Delete Remote Desktop over a Remote Connection?
A Najam
15 points
Can I send Ctrl Alt Delete Remote Desktop over a Remote Connection?
You can use two of these methods to send this command to the Remote Desktop over a Remote Connection.
1) You can use “Ctrl + Alt + End” rather than using “Ctrl + Alt + Del.” You can use the Former Shortcut only in the Client Machine. If you are using VM Ware, then you have to use “Ctrl + Alt + Ins.”
2) If you face any problem using the above method, then you can use the On-Screen Keyboard in the first RDP Session. To use this keyboard, follow the steps.
a. Click on the “Start” menu.
b. Select “All Programs.”
c. Choose “Accessories”, and then, click on “Ease of Access.”
d. After that, select On-Screen Keyboard.
