Can I send or receive phone messages through navi 600?
Hi Paul Digiovanni,
You cannot directly use navi600 for sending and receiving text messages, but you can connect your iPhone 3g using USB cables from apple. You can only add addresses or zip code for navigation. You can read the other function of the navi600 using their manual. Or you can download it here:
Navi600 cannot be use directly to send and receive text messages via phone. But you can still use it by connecting through Bluetooth or by using USB cables.
For instance, using iPhone 3G, you just have to connect the USB cable provided by the device, then add the address or zip code for the navigation.
To learn more about this functionality, you can visit this link.
