Can I set up two Active Directory domains in one network?
Hello
I need to design two Active Directory domains in a user network. Is that possible? What are the things that I need in order to accomplish that? What should to do?
Need your help. Thanks in advance.
Answered By 25 points N/A #102539
Dear Jasper torres
The answer is yes, you can set up two Active Directory Domains in one physical network. Since both the AD domains have separate name spaces, and you want users to be able to log onto both the domains, then you need to create two one way trusts. Domain A trusts Domain B "one way trust", Domain B trusts Domain A "one way trust". This depends on what you are willing to do, this case if you need all the users to log onto both the AD domains. If this is not your case, please give us more details of what you want to do.
Hope this may help you.
Best of luck
