sohel741
10 points
Posted on - 03/05/2012
Hello Experts,
i am using Pentium 4 Â and have ram is 512 MB
Hard disc is 80 GB
Now can i use web cam in my pc? Any suggestions is highly appreciated.
Thanks
Can i set a web cam in my computer
 Yes you can attach your webcam with your PC (Pentium 4).
It  is very easy you  just plug your web cam into USB port and now your webcam is ready to start.
Definitely, you can use web cam on your computer.
The system requirement is OS having windows XP or above. Connect it in system’s USB port and install the driver of that web cam.
Most of the webcams have a USB connection, a driver disk, and of course the camera having the lens which you'll need to adjust somewhere so that you can see it and you too can be focused
Sohel,
You can use a web cam although its a little bit old. To set up a web cam you should follow certain instructions.Â
The type of webcam you require depends on where you mean to set it up. Even the cheapest will work well for still image capture, subject to lighting standard.
If it will be in a bright area then even this $12 one from Walmart will work. The inexpensive webcams have drawbacks in two areas: video streaming and low-light performance. I have given a link. Visit here and you can learn about your present problem and I think you will set up a webcam in your PC.
