Can i split video chats on Skype application?
On Skype during video chats, is there a way or an application that i can use to split the video chats? In a way i can chat with 2 people or more in one session without having to necessarily chat with each individual separately? Is there a video splitter for Skype?
Best Answer by AlfordCharisse
Answered By 0 points N/A #164071
Hi
Skype does not allow to split the video. The new version of Skype split the screen when you minimize and can see a window of cam on top of screen the but if you are chatting with more than one user then it show you cam of them on Skype applications only.
Answered By 60 points N/A #164072
Hi Mr. David Bailey,
I haven't heard about splitting video chats with Skype. I have searched in the internet and Google but there was no possible way for your concern. I suggest you join the discussion on the forum of Skype so that you would be inform to the latest adjustments of Skype. I have attached the link on the lower part of my answer.
Skype Community L When Video Calling on Skype
Answered By 0 points N/A #164074
Actually there is no option to split video chat on skype but i can give you some other solutions that can help you.
1) You can install a third party software that is available on the internet and download to use it.
2) You can use a recorded video for the topics you are actually talking about.
Answered By 0 points N/A #164075
When video calling on Skype, it splits the screen in 3. Skype does not allow you to split the video. Skype splits the screen when you minimize it, and can provide a camera window on the screen.
If you are chatting with the maximum number of users (two or more than two), then it show you a video of them only on Skype applications.
Answered By 0 points N/A #164076
Hello David Bailey,
Even though you can use Skype conference call. Video can't be viewed at the same time
Just one at a time.
Hope this helped you!
Answered By 0 points N/A #164073
Hi David, You can only create a split screen video call recording on Skype with third party software’s. Skype does not render a two person video call at the same size side by side. Other than Skype I made a video chatting application that supports 4 people at a time using Flash Builder. So there is a possibility you may find such application on the internet as well other than Skype. Thanks
