I need help people. One of my floppy disks that contains Word .doc files got corrupted or damaged FAT.
Can I still recover floppy disk data or do I need a software for something like this?
I'm still on a Windows XP 64 bit sp2 system if that matters.
Please help.
Can I still recover floppy disk data?
Hi Carole Reeder
Well there is a way to recover your word file from floppy disk.
I will recommend you a software named “FlopShow V1.2” .
It is used for file recovery and also file used for undelete utility for fat-12 partitions.
It will offer you 100% recovery of your floppy disk.
I hope you will get your way to recover the issue using this tool which I strongly recommend to you.
Joshua Y Roush
