Can I still subscribe to Norton Internet Security?
My free Anti-Virus which is Norton Internet Security trial version is about to expire in ten days. What should I do in order to continue or extend it without paying for subscription?
Hi, It is important to subscribe and get full protection of your PC. What you can try and do to extend your free trail a bit is to uninstall the antivirus you have through the control panel, remove program then click complete removal.Â
Then you can reinstall the antivirus once again and the reactivate it for another free trial duration. It is Important to note that you should also download a resettle from pirate bay, otherwise you may experience a problem of complete deactivation or being disabled from Norton Company products.
You won’t be able to extend it or continue without paying for a subscription. So your best bet would be to switch to a different trial version security software like McAfee which is good for 30 days, after which you’ll have to try another security software’s trial version.
You can also try Kaspersky here:
Or you can just go ahead and use the full free anti-virus version of security software like Avast and AVG. These won’t expire or at least gives you a year of free antivirus protection.
You can also download malware bytes' anti malware as added protection, it’s also free.
Just stay away from suspicious websites, downloads and files and you should be fine.
