haroldski
10 points
Posted on - 08/20/2011
Hey,
I found a box containing the WIP330 with all its accessories, battery and the power adapter. I believe it is still functional since it would still power up. I searched online for its use and functions. This is a WIFI phone which uses the SIP protocol to make telephone calls at low cost or often at no cost at all over the internet.
My question is can I still use this anywhere then? Are others still using this device?
Can I still use the WIP330?
Yeah! Your information that you get are right. You can use this thing to iPhone or any smart phones with WiFi. You can use it to call at minimum amount or cost over the internet. You can use or bring it anywhere unless there is a signal. Many people using this especially for calling via Skype because they find cheap and customer friendly. They prefer to use it because they can save extra bucks every time they are making a calls for friends and family.
These are some good news for you by having that kind of electronics device. Okay and enjoy life.
WIP330
