Can I upgrade the old Feedback Analyzer in my iPad?
I have been using the Feedback Analyzer version 1.0 for my iPad and would like to upgrade to the latest version 2.0. Do I need to uninstall version 1.0 and reinstall version 2.0? Or can I just simply upgrade it?
Answered By 5 points N/A #160690
When there is an available update on any application installed in your iPad, it will notify you or you can check on the App Store. Open the App Store and then click the Updates tab and then click Update on the right side of each application that you want to update. You can also click the Update All button on the top of the Update page.
You do not need to remove the old version because once you click on the Update button; the old version will be replaced with the recent version.
