Hallo!
I am running Windows XP on my computer and I accidentally deleted some files the SHIFT DELETE way and so I do not have them resting in the Recycle Bin. I have read on the internet and found an AOL computer repair as a way that I could recover my deleted documents. Anyone who has ever signed up for AOL computer repair who can explain to me how effective this is before I can sign up? Thanks a lot.
Can I use AOL computer repair to recover deleted files?
Hi Harford,
Losing your files by mistake is the worst thing that could happen especially if it was a very important document. The AOL Computer Repair is an all in one software if you are a tech savvy you can find a lot of tools here that can help boost the performance of your computer. Though it does not have a raving review you can sign up for their 30 day free trial and you can call their helpdesk who would go through the process with you. However may I also suggest a couple of software you can use though these are licensed it has an assurance that it can help you recover your files.
Stellar Phoenix 2013
This has one of the highest reviews among file recovery software and this can recover files even on a non bootable disk. This can also be used to other media devices like CDs, DVDs, USBs and Media Cards. This has a utility that turns back the hands of time and recover your files.
Data Rescue PC3.
This is an excellent tool that makes difficult task of recovering file simple. This has filter tool that makes the process faster as it will only look for the file type that you accidentally deleted. This also includes a boot disk in case you need to retrieve files on a non bootable disk.
 These are just my top picks for data recovery software if you want to view the best recovery software there is you can check this link: https://www.business.com/categories/data-recovery-services/
Hello, Harford Maud
I have read the problem about the files that you accidentally deleted. When a file is deleted by CTRL + Shift + Del it will not go to recycle bin. It will directly be deleted. If you manage to start undeleted process on before Windows overwrites that part of hard disk with new files then you can recover your files.
There are some recovery software to recover a deleted files.
