donaldtbyrd
50 points
Posted on - 03/20/2013
Hello ,
I have a 4 GB USB Flash drive. There was some important data in it. I have heard about Fastcopy Unstoppable Copier which recovers files from hard disk. Can I use it for my USB Flash drive too?
Thank you
Can i use Fastcopy Unstoppable Copier for my USB Flash Drive?
There is no scarcity using any kind of software. You can use any kind of recovery software. In every Recovery software there is a separate option called data drive or you will have to select the drive (for example as shown below). So there won’t be a problem using any kind of recovery software with your data drive. But also you should consider there are some features called hard recovery, it’s better to avoid those kind of recovery since it may harm your pen drive
Taylor B Campus
Thank you
Roadkil’s Unstoppable Copier allows you to recover files from physically damaged disks. The program should also work with USB flash drives since it doesn’t say that it is designed for hard drives only. The program allows you to copy files from disks with problems like bad sectors, scratches, or that just gives errors when reading data.
The program tries to recover every readable piece of a file and put the pieces together. With this method, most file types can be made usable even if some parts of the file were unrecoverable in the end. If you wish to try the program on your damaged USB flash drive, go to Roadkil’s Unstoppable Copier and download the version for your operating system.
You can also use the program as a daily backup system with its batch mode functions. The program is available for Windows 98, Windows Millennium, Windows NT 4, Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8.x including Linux.
