Can I use Gmail offline mode?
Hay guys,
I have heard about Gmail offline.
But don't know how to use it.
Does anyone have any idea about it?
Hay guys,
Hello Mr. Maxi.
Yes Gmail has an option 'offline mode'. You can use Gmail offline if you have a Gmail account.
You have to follow the steps given below to use it:
1) Sign in to your account using Google chrome browser.
2) On the right side, you will see an option 'add to chrome'. Click on it.
3) You will be requested to install a software, install it.
4) Click on 'launch app'. A new web page will appear.
5) Now click on 'allow offline mode' and then click 'continue'.
Now you can view Gmail as offline mode using this page.
Thank you for your question.
You can easily use Gmail offline. For that, you need to install Google Chrome browser. Then, install the extension from chrome web store: https://chrome.google.com/webstore/detail/gmail-offline/ejidjjhkpiempkbhmpbfngldlkglhimk
Then, when you open new tab, click on the button “Apps” on the bottom. There, you will see a blue Gmail icon. Click on it and you will be redirected to Gmail offline. There, you can easily customize your Gmail, check mails, send mails offline.
But be sure that you have allowed Gmail offline to make change of your account.
