hyacint2002
Posted on - 01/11/2012
I am using Exchange Server 2007 for sending and receiving emails. For security reasons, I need to know the steps on how to integrate Exchange Server 2007 to MS Outlook 2007 to make sending and receiving emails more secure. And also, can I use Google apps and integrate it on MS Outlook 2007?
Can I use Google apps and integrate it on MS Outlook 2007?
To integrate or configure Exchange Server 2007 to MS Outlook 2007, you need to perform the following process:
Configure your outlook for automatic profile creation
Auto Configuration Test
Guessmart
Out of Office Configuration
Outlook 2007 Scheduling
For more information, you can visit this link.
Please take a look at the images below for you to know what I am talking about
To integrate Exchange Server 2007 with Ms Outlook 2007, you will need to follow the steps below:
You will need to go to the control panel on your computer and then Open Mail.
Next you will click Show Profiles, and then choose Add.
You will then type a profile name, and then click OK.
Next you will need to choose Manually configure server settings or additional server types and then click Next.
Thereafter choose Microsoft Exchange and then click Next.
You will then type your Server FQDN as the Microsoft Exchange Server name, and then type your Exchange Mailbox Username.
Next you will need to select Use Cached Exchange Mode.
And then you will hit the More Settings button. Click Cancel in case you are asked for a password.
Next you will choose Connect to Microsoft Exchange using HTTP and then click the Exchange Proxy Settings button
And then you will type your Exchange Proxy Settings.
And then click OK, Apply, OK, Next, Finish and OK so as to save the changes.
You can now start Outlook.
-Mathew Stone
