Can I use infrared technology to connect to internet?
Can I use a router with my infrared port to connect to internet? If so what additional stuff do I need?
Hello Shara,
First of all, your concern got my attention. I got a bit curious with regards on infrared router, I thought it’s obsolete since the technology has grown more and more each day and release new updates on IT world. By the way, to answer your question, I’m gonna ask you to open this pdf file online because it is an example of infrared router that can still be used even at this very high technology world. It will show you that it is possible to have a router internet connection via infrared. Different features and specifications were displayed here. It will give you an idea on what type of infrared router you will be using which is compatible to your computer.
You may follow this link for further information about the router.
http://www.smartavi.com/assets/files/b_HDTVRouter.pdf
Please note that this information is from the producer or creator of the router which is located in Canada via SmartAVI. I hope this information is of good help. Thank you!
