Can i use internet connection in my 2 laptops by 1 modem?
I have 2 laptop's and 1 modem. My laptop's have Bluetooth and WiFi.
can I use internet in my 2 laptops together by 1 modem?
Hi James,
Definitely you can do that but you need to have your own router. Router is a computer networking device that forwards data packets between computer networks which create an overlaying internet work. Here are the things that you need to be able to have an internet connection both of your laptops: A network router (wireless or wired), Network adapters installed on all devices to be connected to the router.
A working internet modem (optional) and a web server installed at least one computer in the network.
By the way, I suggest you read also the following:
– Home Network Diagrams
– Wired vs Wireless Home Networks
– Internet Connection Alternatives for Home Networks.
Hope that could help you.
Thanks
– Asis
Yes it is very possible since both laptops are already equipped with Bluetooth technology. Just make sure that both machines’ Bluetooth are working and properly installed. It would be best also to send a file to both computers using Bluetooth to make sure they are working. First select which laptop is the server and which is the client.
The laptop that acts as the server is the one directly connects to the internet using either a Wi-Fi hotspot or the traditional modem. The client laptop is the one that will connect to the server. The type of network you’ll be establishing here is called PAN or Personal Area Network.
In the server laptop:
In the client laptop:
Going back to the server laptop again, you should see a notification in the system tray that says “A
Bluetooth device is requesting to connect to your computer”. Click on the notification and then enter the passkey you received earlier, click Next, and then Finish. Go back to the client laptop and then click Finish.
Select the server laptop and then click Connect. After about two minutes both machines will automatically configure their own TCP/IP address. You can now connect the server laptop to the internet.
Notifications
