anonymous
7060 points
Posted on - 07/19/2011
I want to use iPad applications on my Android device.
Is it possible to run iPad applications on android based phone or tablet? Actually I want some iPad applications that are not available in the Android market.
Kindly help me how to find and install iPad applications on Android.
vrkorn
Can I use iPad apps on my android?
Hi anonymous,
No because it has a different Operating System, just like you want to install Microsoft Word to LINUX.
IPad applications are not compatible with Android. Because iPad and Android are two different Operating Systems. It is just like that someone wants to install Microsoft word to LINUX.
It is the genuine problem that you cannot install Android applications without using the Android market. If your iPad application is not listed in Android market then definitely it will not be installed. You can find that application outside the android market. These non market applications are usually called “3rd Party” applications.
There are two ways to install these special applications and it will provide you a lot of benefits if you learn that how to do this. If you want us to teach you how to install, just message us back so we can assist you in the installation.
Hello Dman,
To answer your question can I use iPad apps on my android?
There is no definite yes or no answer to this question. The practicality (technical workability) and applicability (involving market forces such as competition, being the main contradictions; there are various disparities in the two devices:
1. They are made by different tech companies (Competing Tech Companies).
2. They are made using completely different operating systems. (Like Linux and Mac OS).
An Adobe technology known as Adobe Air has been suggested as a solution to develop for IOS and Android. Apple had cited it as an infringement but it was allowed only recently.
Also See: HTML 5 for IOS and Android by Robin Nixon (McGraw-Hill 2011, ISBN 978-0071756334)that gives suggestions on how to program for mobile phones. Robin Nixon sees this as a great possibility.
All The best.
dianag
hasan7e
Dear friend,
No you cannot, because apple wants to be strictly unique and that's there company policy, and at the moment there is no software that allows cross platform use of application on a mobile OS, and they are using completely different processing system. But as there is a vast number of android user in the market now so the big android maker companies are developing lots of apps for android phones you can have look on the link below:
https://www.bluestacks.com/blog/app-reviews/archive/50-best-android-apps-android-games-august-2012.html
