Can I use multiple display in my computer?
It is easy to use to multiple displays with any update laptop or desktop computer. It have the ability to display both its own and external display. If your computer is not update and it has not this ability, you may require installing the multiple video cards which seaport the multiple display.
Then you must select the dual view mode in Microsoft windows by using following steps. Start—Settings—control panel– then double click to the display icon—click properties then click settings then click the down arrow and select the secondary display. Now your computer is ready for viewing multiple displays.
Yes you can have multiple displays in your computer. First you need to have multiple graphics processing units, or one of the latest graphics processing units that allows you to use all its display connectors and have multiple displays available simultaneously.
You can use it to mirror each display, or have an extended desktop feature, or use the sets of display you have like one whole desktop monitor. For some graphics processing units, you need to have its software updated to be able to use multi-display features. Just check with your hardware manufacturer's website for any update.
Thank you. Hope it helps.
Clair june
