Hi, I am a newly Vbscript programmer and I would like to OpenOffice base in Vbscript workbook containing 8 worksheets, and can access worksheet 1 and worksheet 8 of that workbook using Vbscript.
Can you please show me how doing this in a way that I can understand?
Thank you.
Can I use Openoffice base in vbscript?
Use OpenOffice.org a Microsoft product that works on many different platforms. You will be able to use scripts to execute your programs and manage your office through programming languages such as: Visual Basic, C++, Delphi, VBscript and JScript. Internet Explorer and Windows Script Host will execute the scripts. The code in the example below opens a new writer document and insert some text. An instance of the class will start automatically even
 if OOo is not up and running. Save the code in a file and name it test.vbs. Now, Open your command line and type: csript test.vbs
 'The service manager is always the starting point
 'If there is no office running then an office is started up
 Set objServiceManager= WScript.CreateObject("com.sun.star.ServiceManager")
 'Create the Desktop
 Set objDesktop= objServiceManager.createInstance("com.sun.star.frame.Desktop")
 'Open a new empty writer document
 Dim args()
 Set objDocument= objDesktop.loadComponentFromURL("private:factory/swriter",_ "_blank", 0, args)
 'Create a text object
 Set objText= objDocument.getText
 'Create a cursor object
 Set objCursor= objText.createTextCursor
 'Inserting some Text
 objText.insertString objCursor, "The first line in the newly created text document."&_ vbLf, false
Fore more information please check this link.
I hope this helpful.
