Can I use POP3/IMAP4 to get emails on my Motorola MPX200
I would like to get my emails on my Motorola MPX200 mobile phone and use ActiveSync to get my emails at work.
Can I use POP3/IMAP4?
Dear Jim,
yes the Motorola Mpx200 can be configured with the IMAP and POP3 settings these settings can be reached from the options menu of the email account settings.
Please find the following links that might be helpful in your solution.
on this page read part no 6: Motorola MPx200 Handset FAQ
Motorola MPx200 via Microsoft Exchange
Motorola MPx200 for remote synchronization
Hope it helps.
It is on your mobile phone does it supports java or not. If you are able to run Hotmail or yahoo
messenger then you will be able to get your mails on your mobile phone also.
You can configure POP 3/IMAP services as well.
By looking on your mobile phone i think it doesn't supports the GPRS services and if it does not supports the GPRS services then you will be able to visit your emails accounts also.
But if have a mobile that supports the GPRS services then you will be able to see your mails on your mobile phone.
The Motorola MPx200 is a discontinued 2G phone operating on 2G network band using GSM network technology. It was announced to the public and released on the third quarter of 2003 measuring 89 x 48 x 27 millimeters and weighing 118 grams. It uses mini-SIM card and has TFT display with 65K colors at 176 x 220 pixels screen resolution.
Second display is at 80 x 48 pixels. It runs on Microsoft Smartphone 2002 powered by TI OMAP 710 chipset and 133 MHz ARM925 processor. It supports MMC/SD card expandable up to 1 GB with 8 MB internal storage. The phone doesn’t have a camera, 3.5-millimeter jack, Wi-Fi, Bluetooth, GPS, and stereo FM radio. It has infrared and miniUSB. The pre-installed web browser supports WAP 1.2.1 and HTML (PocketIE).
It runs on removable BA520 Li-Ion 860 mAh battery with standby time up to 96 hours and talk time up to 4 hours. It is available in Liquorice Black color. If the phone includes an email client app, you need to get the correct IMAP and POP settings for your email account. For Google, see the following:
IMAP settings:
POP settings:
For Yahoo, see the following:
IMAP:
POP:
Notifications
