Can I use powershell open zip replacement for Mac files?
I needed an open zip replacement for my mac devices. Can I use the powershell open zip replacement for the files in my mac devices?
Dear fellow!
PowerShell functions include tasks administration integrated with the .NET Framework. Administrative tasks are usually done by Cmdlets (pronounced command lets).
The runtime of Windows PowerShell can be embedded with other applications using a hosting mechanism supported by PowerShell.
You can surely use PowerShell for your Mac devices. Here’s a link to download the application and its compatibilities:
Four kinds of command are executed by PowerShell.
1. Cmdlets, which are .NET programs
2. PowerShell Scripts
3. PowerShell functions
4. Standalone executable programs
