I want my extra monitors to run off in my EGPU set up. Can I work and install drivers all at the same time? I have been searching for answers in various places but only ended up finding the same question unanswered. Can somebody help?
Rogers U
10 points
Betty,
In short, NO, if you do not have the GPU Console Client installed.
This means you need to first have some basic knowledge of Windows and the FAH software.
The GPU Client must be installed and running without any error.
Now open the windows explorer and navigate to the original / first console client was installed
It should be something like
XP/2003:X:Documents and Settings [username]FAH
Vista/Win7: X:Users[username]FAH
Where X is the drive letter of the partition. This path could vary according to the actual installation of FAH
Now copy the FAH folder and again paste it to the same location BUT with a little different name i.e. by adding -2, the resultant path should look like
XP/2003: X:Documents and Settings [username]FAH-2
Vista/Win7: X:Users[username]FAH-2
Now delete the work folder and queue.dat file in the newly copied FAH-x client folder to prevent the new client from duplicating the work unit from the original client folder.
Now Find the FAH client executable from the original FAH client and make a new shortcut (right-click on the [email protected] icon and then select Create Shortcut). After creating the shortcut, move the shortcut to the desktop. Rename the shortcut with a convenient name like GPU1
Now this is the shortcut of the first client, and further shortcuts of other clients may be created using the same method
Now double click on the first shortcut created, and the configuration will start, remember to give different machine IDs to these clients individually. Also set the client parameters correctly
Additional client parameters []? Enter a -gpu x flag. The first client goes to -gpu 0, the second to -gpu 1, etc
And you are done.
James
