qui_75
10 points
Posted on - 10/04/2011
Is Cloud computing necessarily helpful to layman (without professional IT experience) who are into online bussiness? I am a professional nurse but I run my online boutique. How can I use Cloud computing to my advantage?
alphae
15 points
Can an Independent Business Benefit on Cloud Computing?
For sure cloud computing can be used in an independent business, especially if you have plans to expand your business in future. You will save a lot of money that would have otherwise be used to employ IT staff and buying more computers, servers and other computing equipment that will be required to expand the business in future. And also time, you will save a lot of time that may be required to do activities like backing up, running up and down the institution when the server goes down to make things work and cub many other things that may be time consuming.
With cloud computing, you will only pay for the space that you are allocated to you in the cloud. I find this very ideal for the budget of your business considering that it is a small business.
Alphae.
