Can ios 6 be used in iPad2?
Since the release of iOS 6 with its vibrant features I am just eager in testing it on my iPad 2 but I fear compatibility issues and crush, please help.
Hello Mr. Tonny,
Apple has design iOS 6 compatibility and supported devices are iPod touch, iPad 2 & 3, iPhone 4 & 4S, iPhone 3GS, but not all of the features are available on the devices. Try not to get disappointed because there will always be a chance for updates and improvements in the future from Apple.
Navigation, Stream pictures, VIP inbox, and offline activities can be perform on your iPad 2 with iOS 6. I have inserted a graph so you can see what your device capability will be once you download iOS 6.
Not because you have an Apple iPad 2 and its manufacturer, Apple, released a new mobile operating system you can update your device’s OS that easily. It will depend on your device and the availability or compatibility of the new OS to your device. Here are the specifications for the Apple iPad 2.
The Apple iPad 2 is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled and released at the same time on March 2011. Unfortunately, this device has been discontinued and is no longer in production. It measures 241.2 x 185.7 x 8.8 millimeters and weighs 607 grams.
It uses a micro-SIM card. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 768 x 1024 pixels screen resolution. It supports multi-touch and protected by Scratch-resistant glass with oleophobic coating. It runs on iOS 4 upgradable to iOS 9.3.2 powered by Apple A5 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and PowerVR SGX543MP2 GPU. The Apple iPad 2 doesn’t support microSD.
It runs on 512 MB RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 0.7 megapixels which can record video in 720p at 30 fps. It supports a secondary VGA camera. It has a 3.5-millimeter jack; Wi-Fi 802.11 a/b/g/n with dual-band; Bluetooth 2.1 with A2DP and EDR; GPS with A-GPS; and USB 2.0.
It has built-in accelerometer, gyro, and compass sensors. The pre-installed Safari web browser supports HTML. Java is not supported. It runs on non-removable Li-Po 6930 mAh (25 Wh) battery with standby time up to 720 hours. Talk time is up to 9 hours. It is available in black and white colors.
