Hello Techyv.com!
Java is a good program for scripting languages. One key feature is that it is language independent. Now I'm having troubles about debugging because it takes time to do, I was thinking if maybe there are Java development tools that can be used for debugging? If there is, is it user friendly?
Can Java development tools be used for debugging?
Hello Merrill,
This is a question that hundreds of Java developer go through at the very beginning stages of there development career. I would thank you for asking such a great question. Below I have complied a list of tools that allow Java development along with debugging options:
1. Java Development Kit – The JDK it comes with default JAVA debugger JDB.
2. OpenJDK
3. Aicas JamaicaVM
4. GNU’s GCJ (The GNU Compiler for Java)
5. IBM J9 JDK
6. Oracle Corp JRockit JDK
7. Red Hat IceTea
8. Netbeens for Java that provides the debugging facilities.
Thanks!
