Can joomla clean unused images automatically?
Can Joomla clean unused images automatically? I am planning to use Joomla for a website that I will create but I want to know if it can clean unused images every month?
Thank you!
Thank you!
Yes, Joomla can clean unused images automatically.
You need to install a Joomla clean unused images” software that will scan the PC after a fixed time period and identify the unused files.
The interactive part of the software allows the user to authenticate the cleaning procedures.
When authenticated, the marked images will be deleted from the system immediately.
One of the software that can be used to perform such functions effectively is the “Byte Doctor Pro 1.00”.
It provides both the “selective cleaning” and the “clean all” options.
Hello Mr.Richard.
Yes, Joomla can do so. You can do your work with Joomla 3.0.0. It takes 3 steps to install Joomla. It has many features with auto clean up facility.
If you already have a Joomla, you can upgrade to the new version. Then manually set up the time period of Joomla auto clean up. Then it will clean up automatically.
For more information,you can visit to- https://www.joomlatutorials.com/
Thank you for your question.
Notifications
