Can jpg convert bup by changing file extension?
Internet searches. I found that bup files sometimes have two file extensions and deleting that bup extension we can convert into normal with remain extensible.
My question is can jpg convert bup by changing file extension?
And how can I see file extensions in Windows 7?
Answered By 0 points N/A #140842
You can convert jpg to bup by changing the file extension to ".bup"
You can easily see file extensions in windows seven. To see it follow the steps:
1.  Go to your systems “Computer”
2.  Now click the “Organize” placed in left upper side
3.  Select “Folder and search option”
4.  Then select “View”.
5.  Now  disable “Hide extensions for known file type”
Now you can see all file extensions.
