Can Livescribe connect to blackberry via WI-fi or Bluetooth? I would like to share data from my Pen with my Blackberry. I have a Blackberry 9000 with WI-Fi 802.11 a/b/g WLAN and an 8 GB Livescribe Echo with Livescribe Connect.
Can Livescribe connect to Blackberry Bold
Hello! You said that you have Blackberry 9000 with WI-Fi 802.11 a/b/g WLAN and an 8 GB Livescribe Echo with Livescribe Connect. Of course you can Livescribe connect to blackberry via WI-fi or Bluetooth. Basically, Livescribe is a light software. To connect through Wifi Lan you have to follow user manual. At the same time, Livescribe Echo installer and observe that your PC's system configuration is OK. After all, you have to ensure that your system is very healthy by ensuring powerful antivirus. I think you will be able to use it. It's very simple. If still there is a problem, you must give me reply in thread. Best of luck!
