I'm trying out the MagicTV MTV3700TD with the 1 TB capacity, Sigma SMP8655 chip for recording and editing Live TV. Is there a way for Magic TV transfer file to my PC? My desktop is on a Windows 7 64 bit system. Thanks in advance.
Can Magic TV transfer file to my PC?
Hi Donnaa Gordon,
The program named Magic View and Converter has the ability to create markups for all its readable file formats without the document's authorising the application. At the same time it provides the ability to perform measurements in 2D/3D files.We can use this program to convert the file of all formats to PDF,CALS GP4,FAX,HPGL,TIFF,BMP etc. moreover, It is an excellent print control software,Offer print option that entails postmark, watermark and banner.
