Can multiple access points be used on the same LAN?
Asked By 210 points N/A Posted on -
I have 3 access points, that I plan to install on my Local Area Network and I want to use them at the same time.
Is this possible?
Best Answer by Eloisa S
Answered By 0 points N/A #88822
It is possible to use Access points on the same LAN.  You just need to attach all of them, to the same hub or switches via Cat 5 Ethernet cable.
Doing this, will greatly improve your network's wireless range.
Answered By 210 points N/A #88823
If I can use them at the same time, I am pretty sure the wireless signal of each access point will interfere with each other.
What do I do to fix this?
Answered By 0 points N/A #88824
You have multiple access points but according to standard specifications each access point should have its own unique channel.
The range of channels 1 to 11 is used north America. This allows up to 11 access points to be set up on one LAN.
For this purpose, all the access points should have the same SSID.
 All of the devices should have the same Keys, Security Mode, and Logarithm in case of enabling wireless security.
Answered By 210 points N/A #88825
Very interesting. I will go ahead and try this right away!!!
Thank you Eloisa!!!
Answered By 0 points N/A #88826
You are most welcome!
